serp 405 Report post Posted April 3, 2017 wheel style overall view click to enlarge size ET will fit load rating weight part order number center capsorder # bolts order number source 1 5.5 JK x 16 H2 steel R1 63 mm 460 461 will fit on early 463 will NOT fit newer 463 after 6/94 due to tie rod clearance 460 400 02 02461 400 00 02 461 400 01 02 color DB6289) 461 401 01 02 (color 7324m)461 400 07 02 4604010025 Ø 104 mm€3.20 460 401 00 70 460 401 02 70€ 4.79 M14x1.5-10.9 58 mm ball seat Sprinter bolts € 3.38 A 901 401 00 70 Mercedes-Benz€ 102.31 Südrad 2 6J x 16 H2 steel R2 63 mm 460 461 will fit on early 463 will NOT fit newer 463 after 6/94 due to tie rod clearance 460 400 03 02 4604010025 Ø 104 mm 460 401 00 70 460 401 02 70 Mercedes-Benz€ 112.42 3 6.75x17.5 Hsteel 63 mm 460461 will fit on all 463 but not recommended due to 17.5" wheel and missing H2 461 400 04 02 461 400 15 02 4604010025 Ø 104 mm 460 401 00 70 460 401 02 70 Mercedes-Benz€ 294.35 4 5.5JK x 16 H2 R3 38 mm 460 461 will fit 463 460 401 01 02 1074000025 Ø 81 mm€5.96 460 401 01 70 460 401 03 70€ 7.10 M14x1.5-10.9 (19 mm head) 69 mm B6 6 40 81 60 A140 400 01 70 A220 401 02 70 (17 mm head) 85 mm€ 5.36 Mercedes-Benz€ 400.32 5 7J x 15 H2 R4 37 mm will NOT fit newer 463 after 6/94 due to 15" 460461463 18 lb 8.14 kg 460 401 00 02 1074000025 Ø 81 mm€5.96 460 401 01 70 460 401 03 70 (19 mm head)€ 7.10 B6 6 40 81 60 A140 400 01 70 A220 401 02 70 (17 mm head) 85 mm€ 5.36 Mercedes-Benz€ 400.32 6 7J x 15 H2 R5 63 mm use of spacers (min. 25mm) needed for 460/461will NOT fit newer 463 after 6/94 due to 15" 460461463 21.5 lb 9.73 kg 463 401 02 02 1074000025 Ø 81 mm€5.96 460 401 01 70 460 401 03 70 B6 6 40 81 60 (19 mm head) B6 6 40 81 60A140 400 01 70 A220 401 02 70 (17 mm head) Mercedes-Benz€ 423.86 7 6J x 16 H2 63 mm 460461463 463 401 00 02 1074000025 Ø 81 mm €5.96 460 401 01 70 460 401 03 70 B6 6 40 81 60 (19 mm head) B6 6 40 81 60 A140 400 01 70 A220 401 02 70 (17 mm head) Mercedes-Benz€ 423.86 8 7.5J x 16 H2 R6Atik 63 mm use of spacers (min. 25mm) needed for 460/461 460 461463 1100 kg 25 lb 11.3kg 463 401 03 02 B6 647 00 70 2014010125 Ø 75 mm A140 400 01 70 A220 401 02 70 (17 mm head) 85 mm source Mercedes-Benz:$416 source Eurotruck Importers: $361.00 9 7.5J x 18 H2 Ashtaroth 63 mm use of spacers (min. 25mm) needed for 460/461 and early 463 460 461463 1100 kg 31 lb 14kg A463 401 09 02 A463 401 10 02 B6 647 05 99 170 400 00 25 Ø 75 mm €4.28 (17 mm head) 75 mm Mercedes-Benz€ 423.86 10 7.5J x 18 H2 Ashtaroth 43 mm 460 461463 (US version) 1100 kg 31 lb 14kg A463 401 12 02 B6 647 05 98 2204000125 Ø 75 mm €4.28 (17 mm head)75 mm Mercedes-Benz€ 423.86 11 armored vehicle 7.5 x 16 H2 63 mm use of spacers (min. 25mm) needed for 460/461 460 461463 29 lb 13.12kg A463 401 06 02 A463 401 07 02 B6 647 05 48 1074000025 Ø 81 mm €5.96 A140 400 01 70 A220 401 02 70 (17 mm head) 75 mm Mercedes-Benz€ 423.86 12 does anyone have more pictures of this wheel mounted on a vehicle? 5.5J x 16 H2 63 mm 460 461 463 11 lb 5.0 kg A330 400 03 02 view 4604010025 Ø 104 mm€3.20 A140 400 05 70 (19 mm head) A140 400 01 70 A220 401 02 70 (17 mm head) Mercedes-Benz€ 1,994.10 13 IFAVLUVW 6.5J x 16 H2 7.5x16 H2 2 pc aluminum + beadlock 63 mmuse of spacers (min. 25mm) needed for 460/461 460 461 463IFAV USMC A 461 401 03 02 G 10P 945 00 05 4614000125 Ø 71 mm €7.73 A140 400 05 70 (19 mm head) A140 400 01 70 A220 401 02 70 (17 mm head) Mercedes-Benz$695Euro-Truck 14 7.5J x 18 H2RL6 63 mm use of spacers (min. 25mm) needed for 460/461 460 461463 1100 kg A463 401 11 02 B6 647 07 45 2204000225 Ø 75 mm €4.28 (17 mm head) 75 mm Mercedes-Benz€ 529.83 14a 7.5J x 18 H2 63 mm use of spacers (min. 25mm) needed for 460/461 460 461463 1100 kg A 463 401 14 02 2204000225 Ø 75 mm €4.28 (17 mm head) 75 mm Mercedes-Benz 15 8.5J x 18 H2 48 mm 460 461463 1100 kg B6-647-05 47 2204000225 Ø 75 mm €4.28 A140 400 05 70 A220 401 02 70 (17 mm head) 85 mm€ 5.36 Mercedes-Benz AMG€347 16 9.5J x 18 H2 50 mm 460 461G55 463 1100 kg B6 603 12 80A463 401 1302 center cap 2204000125 Ø 75 mm€4.28 A140 400 05 70 A220 401 02 70 (17 mm head) Mercedes-Benz AMG$700 17 more 8J x 15 H2 15 mm 460 461 900 kg C 740 / 0140 2204000125 Ø 75 mm€4.28 A140 400 05 70 (19 mm head) A140 400 01 70 A220 401 02 70 (17 mm head) Mercedes-Benz AMG $500 18 more 6.5J x 16 H2 60 mm Sprinter Van VW LT2 460 461463 1120 kg 25 lb 11.3kg you will need a new set (60 degree head) of wheel bolts Alutec€ 95 19 more 7J x 15 H2 76 mm2000 and later 463 need 15mm spacersuse of spacers (min 25mm) needed for 460/461 Sprinter Van VW LT2 460 461 early 463 1150 kg 23 lb 10.4kg A903 401 11 03 B6 6 56 0150 2204000125 Ø 75 mm€4.28 A220 401 02 70 (17 mm head) Mercedes-Benz Freightliner Dodge $83 20 6J x 16 H2 60 mm2000 and later 463 need spacers 460 461 early 463 1120 kg 60 degree bolts Vantec $150 21 more 6J x 15 H2 6.5J x 16 H2 60 mm2000 and later 463 need spacers 460 461 early 463 1120 kg 60 degree bolts Vantec $130 22 8J x 18 H2 60 mm2000 and later 463 need spacers 460 and early 463 1120 kg 60 degree bolts Vantec $200 23 6Jx15 H2 6.5Jx16 H2 60 mm2000 and later 463 need spacers 460 461 early 463 style LT intended for Sprinter and VW but will fit G SMC about €100 24 more 8J x 16 H2steel black other sizes available 32 mm 460 461 463 460 401 00 70 460 401 02 70 TrueDesignWheel$150 25.0 8J x 17 H2 60 mm use of spacers (min 23mm) needed for 460/461 463 Mono III A220 401 02 70 (17 mm head) Brabus 25.1 9.5J x 20 H2 45 mm 463 Mono IV A220 401 02 70 (17 mm head) Brabus 26 8.5J x 18 H2 silver black 55 mm 463 Mono IV 00-100-16 A220 401 02 70 (17 mm head) Brabus $1325.00 27 9.5J x 20 H2 60 mm 463 Mono VI 00-100-16 A220 401 02 70 (17 mm head) Brabus $1595.00 27.5 larger image 7J x16 H2 front 8J x16 H2 rear 52.3 mm 460 Cap opening Ø 77 mm outer Ø 60 mm recessed Porsche 928 28 7J x 15 H2 23.3 mm 460 900 kg Ø 73 mm 460 401 01 70 460 401 03 70 (19 mm head) A140 400 01 70 A220 401 02 70 (17 mm head) BBS used around $100 ea 29 8J x 15 H2 8 mm 460 900 kg Design CW1 1074000025 Ø 81 mm €5.96 460 401 01 70 460 401 03 70 (19 mm head) A140 400 01 70 A220 401 02 70 (17 mm head)€ 5.36 CW/Borbet Germany€ 204 in the US at tirerack.com 30 does anyone have more images of the 8x16 CV wheel? 8J x 16 H2 5 mm 460 463 900 kg Design CW1 1074000025 Ø 81 mm 460 401 01 70 460 401 03 70 (19 mm head) 69 mm A140 400 01 70 A220 401 02 70 (17 mm head) 85 mm CW/Borbet Germany€ 209 31 7J x 16 H2 8J x 16 H2 43 mm 460 463 1020 kg Design CD 460 401 01 70 460 401 03 70 (19 mm head) A140 400 01 70 A220 401 02 70 (17 mm head)€ 5.36 CW/Borbet Germany€ 214 in the US at tirerack.com 32 more 7J x 15 H2Enduro 23 mm 460 no longer in production 460 401 01 70 460 401 03 70 BWA 33 7J x 16 H2 13 mm 460 706RU M X 910 BWA 34 6.5J x 16 H2steel 63 mm Pinz 460 7101533152 4604010025 Ø 104 mm€3.20 460 401 07 02 Pinzgauer$135 35 more 7J x 16 H2steel 73 mm will make spacers (min 10mm) necessary when used on 460 G questionable on 463 Pinz 460 4604010025 Ø 104 mm€3.20 Pinzgauer € 195 36 8.5J x 17 H2 ???? Pinz 460 401 01 70 460 401 03 70 (19 mm head) Cepek Alcoa 37 10J x 16 H2 -25 mm 460 460 401 01 70 460 401 03 70 (19 mm head) Alcoa 38 6J x 15 H2 9J x 15 H2 -26 mm 460 Alcoa 38 6J x 15 H2 6J x 16 H2steel 75 mm will make spacers (min 10mm) necessary when used on 460 G questionable on 463 Sprinter 4604010025 Ø 104 mm€3.20 460 401 00 70 460 401 02 70€ 4.79 M14x1.5-10.9 58 mm ball seat Sprinter bolts (cheaper € 3.38)A 901 401 00 70 Mercedes-Benz Freightliner Dodge 1 Quote Go to top Share this post Link to post Share on other sites
switch_on 0 Report post Posted August 30, 2024 Просьба перезагрузить\актуализировать фото дисков ! Quote Go to top Share this post Link to post Share on other sites
Ванёк 32 Report post Posted January 14, 2025 Вот 1 Quote Go to top Share this post Link to post Share on other sites
