benzinjection@gmail.com 0 Жалоба Опубликовано: 28 ноября 2024 Used Mercedes-Benz OM606 Turbo Engine in good working condition. Includes the following used accessories: Injectors Power Steering Pump AC Compressor Starter Alternator Intake and Exhaust Manifolds (Basically everything a motor should have, except the turbo and injection pump.) If you would like to purchase other products with your engine, such as an injection pump, turbo, injectors, etc... we can either ship them in a box with your engine or we can install them for you, so your engine is ready to go. Contact us for a quote on labor for installing them. Your engine will be strapped to a pallet and covered. Once you purchase, we will communicate to discuss frieght options. You'll be provided several quotes to choose from. Freight within the USA is usually $250-$500. Frieght outside the USA ranges from around $800 to $1,500 to most countries because we can ship you an engine directly from Europe to lower the cost. *These are used engines and the accessories are not tested. They come from running cars, so generally they are all working, but we can't guarantee the accessories and outer components. There may be imperfections and details that a 25 year old used engine may have, but we do guarantee the engine will run properly. If you would you like to get more info about Mercedes-Benz OM606 Turbo Diesel Engine and purchase their product click here Цитата Наверх Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах
